Hey guys, at the moment my turbo kit is set at 7 psi and I am only using a Vortech 6:1 FMU with regards to fuel. The car will be getting tuned in about 2 weeks. My question for you is should I go ahead and install a Walbro 255lph in-tank fuel pump while the car is in the shop pre-tuning? Or, is the FMU alone enough? Another route I was considering was ditching the FMU in favor of bigger injectors and the fuel pump, then getting it tuned. However, I plan on boosting 7psi for a while and I would rather spend the cash on other goodies if the pump and injectors are not necessary at 7 psi. Basically, since the FMU is already installed, would it be worth buying the fuel pump and injectors if I am going to be spending $400-500 to get it tuned?
fuel pump question???
Re: fuel pump question???
I have yet to drive the car with the kit on it yet. Its been in the shop for the past 2 weeks getting some things done to it including the turbo kit. I've received mixed reviews about whether or not I would need the fuel pump. I definitely agree its better to be safe or sorry. Since the car is also already in the shop, this is a perfect time to have them slap on the pump. Would you guys recommend it? This is the pump I'm looking at. http://www.racingworks.com/walbro255.htm (The Universal Kit)Last edited by reBIRDth; 10-11-2007, 10:21 PM.
Any thoughts guys? I'd like to get this thing ordered today if need be. Would a better option be to get the racetronix kit and if so should I be getting the 99+ LS1 http://www.racetronix.com/RX-F99-FPKG-2.html or the LT1 kit http://www.racetronix.com/RX-FLT1-FPKG-2.html for a 1999 firebird?Last edited by reBIRDth; 10-12-2007, 02:51 PM.
Another vote for Walbro 255.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
yea i was leaning towards the walbro till I read some posts on the fullthrottlev6 forums from people with 99+ fbodys that had issues with the walbro and liked the racetronix. So i'm sort of leaning towards racetronix since i have a plastic tank.
Originally posted by Injected413a year ago it cost me $1000 to replace my fuel pump and have it installed.
scammed?
Its cheaper and easier to do it yourself by doing the "trap door" method in which you cut a whole right above the fuel tank so you dont have to drop it out.sigpic
1997 Camaro RS A4
2006 Chevy Colorado
2003 Kawasaki Ninja ZX6-R
