Meth install...Need help - FirebirdV6.com/CamaroV6.com Message Board
  • Meth install...Need help
    Ok so i have the stage 2 snow performace MAF kit. I have everything hooked up. Everything is hooked up right but for same damn reason, the pump wont go on. I tested the pump to make sure that wasnt bad, and the ground was right by hooking it up to my battery for a quick second and it worked like a champ. Now, I dont know if any of you are familier with the snow kits but Theirs 2 boxes that hook up. Ones a variable MAF timing box, and the other is a VC-MAF. The Green wire (position 4) hooks up to the pump...Once thats hooked up, when you decrease the start up voltage on the VC-MAF controller, the pump should activate. Now, nothing happens. For some reason, that wire is not getting any power...can anyone help me?
    heres the kit I have...http://www.snowperformance.net/product.php?pk=9
    Juiced Rally Red 98 A4<br /><br />Way too much to list....<br /><br /> <a href=\"http://www.cardomain.com/ride/2263415\" target=\"_blank\">http://www.cardomain.com/ride/2263415</a>
    Re: Meth install...Need help
    what kind of hp does that kit give?
      it doesnt add horses it cools the air temp and ups the octane level so u can run more boost
        It add's HP when I can advance the timing when the Meth is injected. Thats the whole point....it takes away KR.
          3 days ago
