What size cold piping - FirebirdV6.com/CamaroV6.com Message Board
  • What size cold piping
    what size cold piping are you using on your turbo kits i've read that 2.5" piping is only good for 400hp
    Re: What size cold piping
    the size of the piping BARELY reflects what hp #'s you can push thru it. Whats more important is PSI
    on that note 2.00-2.5 are common sizes.
      2.5 is what the kit i'm buying is i believe
      Car expresses who you are. If you have a ****ty car, you must be a ****ty person;)<br /><br /><a href=\"http://www.cardomain.com/ride/995979\" target=\"_blank\">http://www.cardomain.com/ride/995979</a>
        yea i wouldnt go any higher than 2.5 or you going to have a serious pressure drop
        76 Camaro Rally Sport-355/TH350- Soon to be LT1/TH350 with a little laughing gas to wake it up...;)
        89 Ram D350 CTD/M5- 1 Ton Dually getting 27 MPG's
          Alot of guys run 2.5-3"...either one, works awesome. With the 2.5" tho, you see a little quicker spool rate then the 3"...i would only go with 3" if you plan on pushing a ton of PSI
          Juiced Rally Red 98 A4<br /><br />Way too much to list....<br /><br /> <a href=\"http://www.cardomain.com/ride/2263415\" target=\"_blank\">http://www.cardomain.com/ride/2263415</a>
