Re: Which turbo for the 1/4?
let me see if i understand what you're saying. he wants 12.0 quarter mile - say 500 hp. a T3/T61 is $836 and will easily make 500 hp...good for 11.5-12.0 seconds. you're suggesting he start with a bigger turbo (T4/T67 is $1025) that is capable of 800 hp, but only use it to make 500 hp. but since it spools so much slower than the T3/T61, he should get ball bearings to help it spool faster. T4/T67 bb $1385...plus cooling lines ~$125. so for his 500 hp, he should spend over $1500?!
http://www.full-race.com/catalog/ind...9afcf90f901730
http://supraforums.com/forum/showthr...&page=13&pp=25
scroll down to dtjazz's post. the borg warner S258 spooled fast enough for autocrossing and made 588 whp.
a gn with a T3/T61, pnp heads, 206° cam, 3000 stall, headers, 3" exhaust ran 10.84 seconds at 24 psi. you don't even need to touch your heads. buy a stattama stage 1 turbo cam, headers, a good set of slicks, and get a really good tune. you should be comfortably in the 11s on pump gas. sub frame connectors, torque arm and lower control arms will help plant the power. the bmr stuff will run $715.
http://www.afterthoughtsauto.com/camaro-suspension.html
