Holset turbo? - FirebirdV6.com/CamaroV6.com Message Board
Holset turbo?
  • Holset turbo?
    with purchasing my truck, i have had thoughts about using a similar turbo as to the holset H1C used on the first gen 12 valve cummins turbo diesel, i know that the exhaust side is a T3 with an 18CM housing and a 3" v band outlet, the inlet side has a 3" inlet but i dont have any A/R #'s on them or comp maps but i was wondering if anybody here has any input or thoughts, also i can change to either a larger or smaller exhaust housing for improved spoolat top end...
    76 Camaro Rally Sport-355/TH350- Soon to be LT1/TH350 with a little laughing gas to wake it up...;)
    89 Ram D350 CTD/M5- 1 Ton Dually getting 27 MPG's
    Re: Holset turbo?
    Its probably too big.
    Find out the size of the exhaust housing and A/R.
    1997 Camaro RS A4
    2006 Chevy Colorado
    2003 Kawasaki Ninja ZX6-R
      Re: Holset turbo?
      like i said you can go from a 21CM all the way down to a 12CM housing they are not that big of a turbo i can get you guys some pics for reference sake but i am going to need to contact holset for specs
        Re: Holset turbo?
        H1C have various compressor wheels, so you definitely need to call holset, either way the wheels are in the 5Xmm range (~52-55mm respectively). Most of their housings are divided so you either look for a non-divided unit like maybe one from the HX series. You want to be around (totally street) 9cm^2 or the other extreme 12cm^2. The later been ~.8X in std A/R nomenclature; again if the 12cm^2 is divided you will have to run a pulse setup to take maximum advantage...
        BTW dependent on turbine housing, I have actually seen maps to suggest 600hp from this units, very capable...
        hth
        THE ORIGINAL 3800SII turbo...<b><i>NOW SERIES-III</i></b>
          Re: Holset turbo?
          i was doing some searching and the 9cm housings are non divided and have an A/R of .65 which would probably be pretty ideal for street use, these housings cam on the hy-35 off the auto trucks and have the same compressor housing/wheel as the hx-35 so this is probably the most ideal set-up i know they are capable of supporting 25+ PSI of boost which i will never see in my car, im still going to have to do some searching so do you think that is a viable option...
            Re: Holset turbo?
            You are correct...it is fine.
            gl
              Re: Holset turbo?
              its fine i have put one on a merkur before and it ripped. i would run it.
                Re: Holset turbo?
                what size/model holset?
