with purchasing my truck, i have had thoughts about using a similar turbo as to the holset H1C used on the first gen 12 valve cummins turbo diesel, i know that the exhaust side is a T3 with an 18CM housing and a 3" v band outlet, the inlet side has a 3" inlet but i dont have any A/R #'s on them or comp maps but i was wondering if anybody here has any input or thoughts, also i can change to either a larger or smaller exhaust housing for improved spoolat top end...
Holset turbo?
Re: Holset turbo?
like i said you can go from a 21CM all the way down to a 12CM housing they are not that big of a turbo i can get you guys some pics for reference sake but i am going to need to contact holset for specs
76 Camaro Rally Sport-355/TH350- Soon to be LT1/TH350 with a little laughing gas to wake it up...;)
89 Ram D350 CTD/M5- 1 Ton Dually getting 27 MPG's
Re: Holset turbo?
Originally posted by ninety4three4with purchasing my truck, i have had thoughts about using a similar turbo as to the holset H1C used on the first gen 12 valve cummins turbo diesel, i know that the exhaust side is a T3 with an 18CM housing and a 3" v band outlet, the inlet side has a 3" inlet but i dont have any A/R #'s on them or comp maps but i was wondering if anybody here has any input or thoughts, also i can change to either a larger or smaller exhaust housing for improved spoolat top end...
BTW dependent on turbine housing, I have actually seen maps to suggest 600hp from this units, very capable...
hthTHE ORIGINAL 3800SII turbo...<b><i>NOW SERIES-III</i></b>
Re: Holset turbo?
i was doing some searching and the 9cm housings are non divided and have an A/R of .65 which would probably be pretty ideal for street use, these housings cam on the hy-35 off the auto trucks and have the same compressor housing/wheel as the hx-35 so this is probably the most ideal set-up i know they are capable of supporting 25+ PSI of boost which i will never see in my car, im still going to have to do some searching so do you think that is a viable option...
Re: Holset turbo?
Originally posted by ninety4three4i was doing some searching and the 9cm housings are non divided and have an A/R of .65 which would probably be pretty ideal for street use, these housings cam on the hy-35 off the auto trucks and have the same compressor housing/wheel as the hx-35 so this is probably the most ideal set-up i know they are capable of supporting 25+ PSI of boost which i will never see in my car, im still going to have to do some searching so do you think that is a viable option...
glTHE ORIGINAL 3800SII turbo...<b><i>NOW SERIES-III</i></b>
