Hello... Looked over the board several times after I started building a custom turbo setup for my customers 99 Camaro.
Here's pictures... It's up and running but need alot of help with HP tuners. I'm usto FAST systems and Tuner Pro which is used on alot of older OBD1 GM vehicles....
Be glad to hear any advice you guys have with WOT fueling.
Here's the parts list:
Drivers side exhaust manifold is a 99GTP upside down/forward facing.
TA 49 Turbo (Buick GN) Flows 800cfm/Supports 550hp.
P/S Manifold I fabricated.
Connecting pipes to flange.. I fabricated. Stainless downpipe/to flex joint.
Cut K member and welded in 3.25 very thick steel exhaust. (Minimal pipe down towards ground) Good clearance.
42lb/hr fuel injectors
Warbro 255lr/hr fuel pump
Throttle body relocated with pipe (fabed by me)
Other odds/ends. ;)
Anyone that knows HP tuners well please e-mail me UR50SLO@aol.com
Thanks, Scott~
Btw... the front pipe actually fits better.. the owner put the turbo back on a little off from where it should be... He's having all the exhaust powder coated so it's all coming back off in the next few weeks anyway.
![](http://www.michaelrenz.com/upload/files/99Camaroeng1.JPG)
![](http://www.michaelrenz.com/upload/files/99Camaroeng2.JPG)
Other odds/ends. ;)
Thanks, Scott~
