As some of you know I'm doing a turbo setup so I was wondering.. Along with a new turbo Cam should I look into rockers or would it even make a difference? Any advice or opinions on which cam to buy would be awesome too. Oh and the car needs some streetability since I have no trailer to pull it to the track on. I've just recently recieved funds for my project so I want to start buying parts. Heh i'm scared of buying something then regretting it.
Rockers with a Cam?
Re: Rockers with a Cam?
as far as i understand, dan, did not have a good amount of luck with the pro mag on fitment and what not. make sure you do your homework before actually getting into this kind of stuff. i just recently started and im ADDICTED not to mention broke for brief periods in between paychecks.
Originally posted by UDLOSE98I ran a stage 4 stattama turbo cam and 1.7 comp cams pro mag rockers. It was a damn good setup, loped very very nicely and made gobs of power with the turbo.
If i recall, you BARELLY got your car to run and in the end...didnt even really get to drive it before it got parted out...
Shoot Linx or Turbov6camaro a PM with your question...they will tell you exactly what you need.Juiced Rally Red 98 A4<br /><br />Way too much to list....<br /><br /> <a href=\"http://www.cardomain.com/ride/2263415\" target=\"_blank\">http://www.cardomain.com/ride/2263415</a>
Originally posted by rdrr96as far as i understand, dan, did not have a good amount of luck with the pro mag on fitment and what not. make sure you do your homework before actually getting into this kind of stuff. i just recently started and im ADDICTED not to mention broke for brief periods in between paychecks.
And thanks for the direction Kidcamaro.
TEAM C6V6
Originally posted by Kidcamaro98If i recall, you BARELLY got your car to run and in the end...didnt even really get to drive it before it got parted out...
not to mention i ran a stattama stage 3 cam and 1.7's for over 3,500 miles.
Originally posted by HighhpI run 1.7's on top of my IS4 camLast edited by Blizzard242; 01-30-2008, 05:32 PM.
TEAM C6V6
