will i be fine as far as not running dangerously lean at high rpms and wide open throttle with stock injectors and a 6psi S/C. i know i wont be once i decide to go 12psi, just hoping i dont have to spend the cash for injectors until i can save up a little bit.
If you have a FMU you can run on stockers. And yes those injectors would work and so would stock GTP injectors which you can get for like 50 bucks for the six of them
