Belt routing and length - FirebirdV6.com/CamaroV6.com Message Board
  • Belt routing and length
    I figured forced induction cars would know it the best so.. whats a good serpentine belt length and route if I want to do away with my air conditioning?
    TEAM C6V6
    Re: Belt routing and length
    so are you NA or FI?
    Take a piece of kite string and wrap it around, then measure that for your length. Maybe go .5" shorter so you get some good tension on it
    http://www.bowtiev6.com/
      /\ bingo, i would use twine for mine.
        Oh I will be FI, just getting the parts together hence the question. Yeah I know about the string idea, I was hoping that someone might have already done the work so I wouldn't have to :) Heh thanks anyways.
        TEAM C6V6
          What kind of FI are you getting?
          If it's Powerdyne then it would be hard to set it up without the AC pulley.
          The twin Belt Procharger that Jen or Pathogen use would work great. But the Mach Performance Procharger one also needs the AC pulley to make it work properly.
            Heh, I have a turbo sittin in my room... a leaky one. a turbo none the less though. And Thor, I really like your 98 bird. That's gorgeous.
            TEAM C6V6
              I can give you the belt size if you are deleting AC compressor and the Idler pulley.
                Yeah I'd really appreciate it.
                TEAM C6V6
                  Its 6 rib by 61", autozone part number is 610K6, but I will tell you this their will be a lot of chatter with the way you route the belt, so some people opt for a bigger tensioner pulley to get more of the belt on the pulley.
