Soooooo next step. I have a walbro pump ready to be installed. So I need new fuel injectors. t3/t4 60 turbonetics turbo. It will eventually get intense stage 4 heads and eventually a real aggresive cam. So what lb fuel injectors should I be looking for? Actually what is it that determines the size injectors that I'll need?
Injector size?
Re: Injector size?
what kind of boost are you going to be running and what hp range is your target?
Re: Injector size?
Honestly I don't know how much boost I'll want to be running or the HP range. I know I want to get into the 11s range like yourself :) But I suppose I'll start with 9psi seeing as thats the spring in my wastegate.Last edited by Blizzard242; 02-24-2008, 07:23 PM.
TEAM C6V6
Re: Injector size?
if you are shooting for those kind of numbers, then ya get 42.5s
