well the time has finaly come. Ive had a powerdyne and all kinds of parts in my room for about a month now and spring break has finaly come, so im beggining the installation now. already hit a road block though haha. still excited though :D
finaly installing supercharger!
Re: finaly installing supercharger!
question already. the sensor that plugs into the side of the lid...the kit i bought has a plugin for that on the side of the tube that goes from the TB to the S/C, so which one should i plug it into? or does it not matter. also, how would I seal up that hole in the lid? thanks
1999 Firebird Y87/W68
put it in the discharge pipe going from the sc to the tb. That is your IAT sensor and it tells the computer how hot the air is and the computer adjusts timing according to that and the table in your PCM
Originally posted by 99BlackW68 View Postwhere did you get the red tubing that runs from your brothers TB to the supercharger? that would be perfect for my application. thanks
You can find them pretty cheap on ebay.
Search came up with this:
http://forum.camarov6.com/showthread...&highlight=fmu
yes, its for a civic. but it has nice pictures.
Originally posted by 99BlackW68 View Postalso, the FMU, where does that tie into the fuel line at? if someone could post pictures of where theirs is that'd be great. I know how to do everything except install the FMU. thanks.
Fuel hookup you unhook from the fuel rail and run the line that went to the rail into the fmu, and then from the fmu into the rail.
Originally posted by 97rs4life View PostFor the FMU we tee'd into the MAP sensor vac lines and took vac line over to the driver's side where the FMU is located. Make sure to put a one way check valve inline going to the FMU though
and Cody, yeah ive been working like crazy. found out i had an exhaust leak at the collectors where they meat the Y-pipe when i first fired it up friday nght. the paper gaskets ripped when the guy ran 3" to the back, so we unbolted them and put in aluminum gaskets in last night. today im starting on the S/C.
hey call me and ill walk you through it 2817880134Last edited by 02camaro3800; 03-09-2008, 11:34 AM.
We already took the FMU off and put in 36# GTP injectors as the plan is to bump it up to 9lb pulley. Plus we were having issues with maxing the stockers out with the FMU as we are seeing 7-8lb of boost on the 6psi pulley. lol.
But it really is simple to do, just follow the walkthrough on grayman's site for the FMU and you will be fine. He has pics to on it
