so i added a breather filter onto my valve cover. now every time i go into boost i throw oil vapors all over everything. has anyone else with a 3800 had this problem and if so what you did to fix it. i was thinking about a catch can for it but not sure how the oil goes back into the system.
breather filter mod
Re: breather filter mod
you plugged the pcv hole right?
How much boost you running and what kind of breather do you have? The one that screws into the oil neck or did you remove your neck as well and throw a breather on?
fifteen to twenty pounds on a 35r I did not plug off. My pcv since it is built into my intake manifold I don't know how the breather filter is one that screws into the valve cover spectre auto zone cone type
Originally posted by 97rs4life View Postyou plugged the pcv hole right?
Duh.
There is a small bypass around the TB plate that feeds air DIRECTLY into the crankcase. This is part of the PVC system. Unless you plug that line - like 97rs4life asked.Robert - owner www.FirebirdV6.com/CamaroV6.com
Raven
I have yet to hear success from a valve cover breather on these cars.
Andrew and I both plugged the PCV inside the TB and drilled holes to vent outside the TB and havent had a single problem yet.sigpic
1997 Camaro RS A4
2006 Chevy Colorado
2003 Kawasaki Ninja ZX6-R
Im out of town and not near my car ( :( ) so I cant take any pics. Sorry. I'll be home early next week and can take some pics then.sigpic
1997 Camaro RS A4
2006 Chevy Colorado
get one a sweat wrist band (like for basketball) and put it around the breather, does wonders. change it every couple months2002 NBM Pontiac Firebird Formula<br />Mods: stock...<br />1997 Chevy Camaro *Gone*<br />Mods:Borla,headers,Magnaflow cat, SLP intake, NOS 5175
yea take off your tb and there is a little hole that you have to tap and put a plug in. You can see in the tb where the hole is by looking through the inlet. Graymans site has a walkthrough of it
