I will be installing a 3/8" oil plug in my oil pan. Is it a bad idea to JB weld it after it is threaded in?
JB Weld on oil plug?
Re: JB Weld on oil plug?
Are these for turbo oil lines? You're talking about oil fittings and not just a plug for the pan, right?
Probably depends on what type you get but some turbo guys will chime in. I don't see why you couldn't JB weld for security but you should be able to get some type of fitting/bung that wouldn't need anything else.Last edited by NCState98; 04-22-2008, 02:21 PM.\'98 Camaro V6<br />Appearance... pleasing<br />Performance... just a little extra air.
Its a good idea to drop the pan but you dont have to. If you dont drop the pan, then use vaseline on the drill bit to get the metal shavings and use a REALLY strong magnet on the bottom of the pan to catch anything that may fall in. Then when you change the oil, pour fresh the oil thru the system several times with the drain plug out so that it washes out any remaining shavings as well.sigpic
1997 Camaro RS A4
2006 Chevy Colorado
2003 Kawasaki Ninja ZX6-R
by 187sharkHi all new to the community here. I have a 2014 RS 6 speed manual... and so about a year ago my tail lights got cracked and eventually the plastic housing...6 days ago
by ssms5411Still trying to find oil leak on my Camaro, it’s a tough one. I think it is the oil pressure sender myself. Leaking when raving and going into boost....2 weeks ago
