Rear Mount Turbo - FirebirdV6.com/CamaroV6.com Message Board
Rear Mount Turbo
  • Rear Mount Turbo
    I have a 2000 Camaro Coupe. I happened upon a turbo from an 87 regal Grand National for fairly cheap. A buddy and I were thinking of trying to rig a rear mounted system out of it to negate the need for an intercooler. Anyone have thoughts?
    Re: Rear Mount Turbo
    Eh, a few people have them and make good dyno numbers, but track times were terrible and boost lag was atrocious. Personally, I'd MUCH rather have a conventional turbo setup. Plus FMICs = hotness :cool:
    1997 Camaro RS A4
    2006 Chevy Colorado
    2003 Kawasaki Ninja ZX6-R
      I fabricated my own Remote Turbo System with intercooler...
      http://www.cardomain.com/ride/2516564/4
      "atrocious" .... LOL ... I wolud not say atrocious but more yes...
        Sorry, I guess that was a little harsh lol. There was another guy on FTV6 that had a rear mount set up and said the boost lag was pretty bad though. I think it would be a fun street car no doubt.
        1997 Camaro RS A4
        2006 Chevy Colorado
          travis...
          Why are you using an FMU if you have larger injectors and HP Tuners?
          1997 Camaro RS A4
          2006 Chevy Colorado
            Good question.
            TEAM C6V6
              thats a pretty tight setup. So the disadvantages are longer boost lag. advantages? looks easier to install.
                So lemme just throw this up in the air and correct me if I'm wrong but.. If the post turbo pipes to the intake side are longer then you get boost lag because there is more volume of air to compress? And if that's right does this apply to the pre-turbo exhaust pipes as well? I can't see that this principle would effect the turbine side as much as it would the compressor.
                TEAM C6V6
                  I'm not FI, but it seems pretty logical that the longer your pipes are (both) the harder its going to be to get that air moving. Head loss and whatall and whatnot. On the other hand, once it gets going, it might pick up a bit more velocity...which won't matter much I suppose.
                    Go to the STS Site they have all the questions you guys are asking ansewred on a FAQ page.
                    Basicly you need a smaller A/R housing on the exhaust side of a rear mount turbo since the temps drop and the air/exhaust condenses by the time it reaches the back to spin the exhaust wheel. (why the smaller housing is used to reduce lag/spool)
                    The longer intake side makes little difference when the drive side is properly sized to the temp and exhaust velocity.
                    I've got nothing against rear mount setups if done correctly. I would take steps to make the exhaust flow prior to the turbo as good as possible before going that route.
                    I would intercool it even with a rear mount. It'll always be benifical with a effecient intercooler in line.
                    Hope that helps,
                    Scott~
                    BTW... Is that a stock GN Turbo?
                      Thanks for all the replies. Ease of install and minimum cost is what we're going for. I don't intend to ever race it on a track, just as a street car. I wanted something to give it a little more pull so it performs a little closer to how it looks. The friend who was going to install it with me is a welder, and a good one at that, so i'm not worried about that part.
                      We had planned on removing the exhaust and running a new pipe from the manifold to the turbo. Then we were going to run the exhaust straight back from the turbo. We were then thinking of running the intake back and to the left to take the place of the former second pipe out of the muffler. I wouldn't have dual exhaust anymore, but the stock isn't true dual exhaust anyway, so i wasn't worrying about it. I was also planning on punching out the cat and running a pipe through that so it looks like its still functional.
                      It is the stock GN turbo, not the GNX, but a turbo is a turbo and its better than nothing.
                        word of warning, if you fake your cat and get caught...yeh.
                        sounds like a fun project! be sure to do a writeup
                          travis...
                          Im not thats old pic ....
                            Nice setup Travis, very impressive. I was thinking of painting my wheels black like yours in the older pics doesnt look bad at all think I might do it.
                              What adapter did you use? I'm trying to find an adapter with a return line so I don't have to tap my pan.
