I just wanted a refresher cuz its been a while. car has been perfect for couple years so that kinda put me out of practice with these theories and knowledge.
Has anyone had success with that companies 'race rigging' of the bd11a (the fancy bearings, shim, blower shell venting, and/or something with a washer or spacer to keep the internal belt from wondering?) AND THEN using an air-air intercooler? If that race rigging actualy works then smaller pulley could be used to make up for the psi drop from the intercooler....???? (see, told you im rusty)
Background: Wont be going beyond 6psi (bigger injectors + modded fuel rail, etc. is too big of a hassle if the bd11a cant be safely coupled to an air-air IC as a dependable daily driver, IMO) unless needed modifications to my current system are atleast somewhat affordable, benificial and dependable. Yes, i know hi performance = hi stress but i think most of you know what i mean when i say i want to keep my modded car as my daily driver. (if i wanted a weekend only car i would not be modding an iron block v6)
I like the sleeper aspect of the BD11a vs the loudness of the gear driven XB1A.
As for water injection as an intake air cooler: easier said than done. the benifits are far reduced (i understand) if i were to plumb the water nozzle into the upper intake manifold rather than relocating the MAF Sensor closer to the blower so as to allow placing the water nozzle further up stream from the TB rather than behind it. MAFs can be expensive, combined with cost of water injection system and im half way to stage two cylinder heads.
Please refresh my memory or share your experience on these matters. searching mainly yields other peoples similar questions and im mainly wondering if anyone has performed these mods to their powerdyne with or w/o success. TIA, g
