97 Camaro from Board Member almost complete - FirebirdV6.com/CamaroV6.com Message Board
  • 97 Camaro from Board Member almost complete
    Here's pic's of the 97 I've been working on. Been a HUGE wait for turbo problems from the vendor he purchased it through and then several parts I had to get on my own to use a external wastegate and all the pipes.
    I did this on as much of a "Budjet" as possible. There was hardly anything to work with when I got the car. It had stock manifolds with a under the K member merge pipe up to the turbo. The mount from the block to the turbo was broken off and poorly welded. (So were all the pipes for that matter) Pipes hit by speed bumps or other stuff.. it was very torn up. (Thus the reason under the stock K-member turbo pipes are not good for street drivers.) With a TUbular K it could be possible and have good clearance. Or if your willing to cut into it like I did on the 98 and put flex pipes in.
    The turbo was not even hooked up to the inter cooler piping. The IC was mounted flat(Horizontal) not vertical (as it is in the pic's below) I re-used some of the pipe's from the old setup to try and save him some $ since it won't effect much in performance.
    The placement of the turbo/wastegate and downpipe seem to work very well.
    No pipes go under the K-member. This is a A/C Delete car. Also a 5spd.
    He was told the Injectors were 43lb/hr .. they are not.. the numbers have been ground off. On HPTuners I had 25% correction at idle... (Perameter was 38lb/hr. Went down to 30.. same..... ended up at 22lb/hr to have 3% correction and be able to drive for a few test down the street with good results....
    I'd like to elimintate that elbow before the MAF.. it's one of my pet-peeves but the $ isn't there.
    Several things he and I need to discuss about options.. battery re-locate so I can put a 4" inlet/K&N on it and several other things. It's got some good potential!
    We'll need to get at least 40-50lb/hrs in here before I can go much further with a fuel/timing tune. But it spools almost instantly like the 98 Camaro.
    Hope this inspires more guys :rock:
    ~Scott
    Re: 97 Camaro from Board Member almost complete
    Wow, it sounds like you were working on my car. Under K pipes with horrible welds. Looks like you're doing good with what you have.
    I'm jealous of the FFH. I've got some pacesetters on mine but I still have the stocker 98 manifolds. Now it looks like the drivers side manifold is just turned around but I can't quite see what you did with the passenger side. I heard that was the hard one to deal with. What did you do with it?
    I've got a tubular K member waiting to go in so I'm totally torn on what to do, FFH or redo the under K pipes. Redoing the under k pipes would be considerably easier but of course the performance isn't going to be the same.
    Also.. I have my serpentine belt set up exactly the same. Boy oh boy does it love to wobble like crazy at low rpms. Are you getting the same effect? I put a larger pulley on the tensioner.. and it fixed it temporarily. It just seems like there's not enough room left on the tensioner for when the belt stretches out some.
    Looks good though. Yay for budgets.. :tdown:
    TEAM C6V6
      sweet set-up. looks cool, whats the specs on the turbo? boost numbers? expected power?
      do you have any under-car shots? just curious to see how the piping is run.
      looks good, real nice job. good luck with it. have any pics of the 98 you were talking about?
        He ordered the turbo. I'd have to see if I can find the page he'd ordered it from. The company sent it with the wrong exhaust housing and we waited forever for the correct replacement.
        There is no A/C on the car. I ran the Down pipe right were the compressor would be.
        I'll be putting it back on the hoist shortly. I'll get some under car pic's for you.
        I do have all the pic's of the 98 Camaro. It's at 12.70 at 108mph now on all stock engine/trans and a posi 3:42 rear end.
        Send me a e-mail at UR50SLO@aol.com I'll get the pic's over to you.
        Thanks,Scott~
          What board memeber if he/she doesn't mind answering?
            Its my car Scott has been working on for the past 8-9 months. Like he said we have spent most our time waiting on parts.
            Before he started working on it I had done a couple cam swaps, heads, gears, ect. also, writing up the sticky for the head flow analysis.
            SLP CAI, RK Sport headers, P&Ped heads and intake, GT2 cam, Upgraded valvetrain, Z28 rear axle with 4.10s Tx Spd tune, Z06 rims, 2.5\" exhaust to flowmaster, 160* thermo, B&M ripper, upgraded ignition, rockford fosgate 12\" with sony xplode amp and HU.
