bov + powerdyne? - FirebirdV6.com/CamaroV6.com Message Board
bov + powerdyne?
  • bov + powerdyne?
    been searchig a long time on this charger set up understand all that is needed to make it work but dont see any thing about blow off valves do these kets not need one? I would think they would but dont know for sure also have not seen ant on set up pics could some one help me out and explain why they dont need one or if so which work best and best placement
    thanks !
    1999 Camaro V6 A4<br />Navy Blue metallic<br />Intake+Exhaust+4.10+?=?
    Re: bov + powerdyne?
    As far as I've seen and read they NEED a BOV, but some people do have them.
    1997 Camaro RS A4
    2006 Chevy Colorado
    2003 Kawasaki Ninja ZX6-R
      I ran mine without one for a couple months and it was fine, but to reduce stress on the powerdyne people put them on and as did I. I simply welded two bungs one on the outlet piping and one on the inlet piping to the SC, then i put 1 inch piping to connect each bung to the bosch bypass valve. Also had the vaccum line on the valve obviously. On powerdynes its not so much of a blowoff valve that blows it into the engine bay its just a bypass valve to send the air back into the inlet when the car is under vaccum and not boost. This just keeps air from being forced back into the supercharger unit when not on the throttle, the extra air is just pushed through the valve and circulated around.
      If you type "bosch blow off valve" or bypass valve into ebay a simple black plastic valve will show up, i think i got mine for like 8 bucks shipped. that will work just fine, no sense in wasting money on an expensive one..
      1999 Firebird W68<br /> <a href=\"http://www.cardomain.com/ride/995565\" target=\"_blank\">http://www.cardomain.com/ride/995565</a> <br />-Derek
        Bosch is a waste of money. I've gone through 3 of them. THe diaphram on that thing tears easily.
        Just get a quality BOV and BPV and let the air blow off to the atmosphere instead of reentering again. I have Typhoon. I used to know someone who used Greddy and it worked great.
        You weld a small pipe at the bend of your discharge tube and install your BOV there.
          thanks this helps alot! I assume the vac. line connects from the pass. side of the intake manifold to the bov? correct me if im wrong
            Any vac line behind the throttle plate. Which they all are so.. There ya go.
            TEAM C6V6
              best one to use is on the pass side. Its has a 90* nipple on it..simply make a t , reconnect and run the other to the bov..done.
