so i want to run a turbo setup eventually, but i want to finish the rest of my mods before i do that
my next mod is a cam, i know they have cams designed for turbos and f/i cars, will a cam for a turbo be fine to run for a while before i have the turbo
also i am pretty sure you need custom headers for a turbo, will these work fine without a turbo?
you can run a turbo cam NA, just wouldn't be getting your full potential out of it
headers, if you go FFH then no you wouldn't use them for NA. If you had normal headers and then you would have to run an under the K-member setup to use them
1 day ago
