i was wondering if i can make a Grand National turbo setup work on my car,i can get the entire setup for under $500 would it work and what would i have to do and need if it can be done,im looking for some ideas and recommendations.
Grand National Turbo
Re: Grand National Turbo
engine and all or just the turbo setup? I have seen a GN motor and turbo in a 4th gen before and it took some fabbing and $$ to work
and why gen tech for this? This is FI
If you are talking about the manifolds fitting onto Series II heads then the answer is no, they wont fit. You will need Series I heads which will require a Series I block, thus you will need an entire Series I motor, pcm, wiring harness etc.sigpic
1997 Camaro RS A4
2006 Chevy Colorado
2003 Kawasaki Ninja ZX6-R
I think you can use the turbo with the internal wastegate on it , then everything else would need to be fab. up. I'm currently building a system using GT35R turbo with a T4 flange setup with FFH and a 31X12X4 intercooler with 3'in/out . Also 3" down pipe going to my existing exhaust. Having the Tub. K and A arms will make routiing much easier. Also Tial 38mm waste gate, and the list continues.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
As stated above... the turbo will work as will any series of the GN turbos.
But the heads and designs are vastly different between the GN 3.8L and the series2.
I will have a forward facing header kit ready very soon that can use a GN turbo.
A stock GN turbo will support 350hp. and flow about 500cfm
TA49 turbo (one step up) will support 550hp and flow just over 800cfm.
Then it go's up from there (Size wise)
The Series2 engines can handle alot of power in the stock forum. The first one I did is currently going mid 12's on 93oct through the mufflers on regular radial tires with a totally stock engine/trans/converter.
~Scott
scott, I'm still waiting on you to finish a set, I have 2 sets atm, one being blown through, and the other I'm not happy withCar expresses who you are. If you have a ****ty car, you must be a ****ty person;)<br /><br /><a href=\"http://www.cardomain.com/ride/995979\" target=\"_blank\">http://www.cardomain.com/ride/995979</a>
Originally posted by UR50SLO View PostAs stated above... the turbo will work as will any series of the GN turbos.
~Scott08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
It'll be more than one set. It will be full production.
I want it completed and set cost before posting a thread and becoming a vendor.
This is only one part of the picture to come for this engine and F-body.
Oil feed/return kit
And cold side to follow.
I've got a full time buisness to run during the day and project's too.
This is just another fun thing for me.
I'll post pictures of the parts being used to create the pass. header and crossover on this or the Firebird thread.
This 69Mach1 on the hoist is holding me up. All that's left on that is exhaust and Dynomax isn't shipping it till the 30th. Grrrrrr.
I might have to take it off the hoist and put the bird up there.
~Scott
Scott, I got my 3" dynomax muffler here ready for me to install this week , and soon a battery relocation kit and coolant reservior. Gives me something to do. Get that firebird going and forget the Ford.LOL Good luck with everything.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
by DongrossmdI’m new. I actually don’t own a Camaro or firebird. I do have a 2000 Camaro 3.8 fly by throttle and 4l60e. This is installed in a 1980 Triumph TR7...14 hours ago
