im gathering the parts, so far i have the turbo and the plugs and wires but i was curious if it would be fine to use stock injectors from a ls1 car, or do i need bigger injectors than those, they are 24 lbs/hr
Starting my turbo build
Re: Starting my turbo build
what year is your car and it depends on the boost you plan on runnign i am running 87% injectory duty on stock injectors with very few mods2001 Camaro 3.8 A4
1991 3000GT VR4
2001 Mitsubishi Eclipse GS
Also depends on how big of turbo and cfm, I would think 36lb injectors at least with 12 PSI or might have to go 42lber's. Thats why I bought 65(60) lb injectors to cover me if the 36lb injectors I'm running max out. I think most have ran stock injectors and FMU up to 8 PSI.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Whats the specs of the T25 , so it doesn't choke up top in the RPMS?08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by Blizzard242 View PostI believe I've heard people running up to 12 psi on a stock engine.
You wont be able to boost too much with the stock injectors unless you use an FMU. 24's may be enough for a little baby turbo with low boost, but thats about it.
Originally posted by Fondle View Postwhat specs did you want?
A T25 sounds puny. I think you'll upgrade to a 60-1 or 62-1 very quickly.sigpic
1997 Camaro RS A4
2006 Chevy Colorado
2003 Kawasaki Ninja ZX6-R
damn i just had all the specs up and now i lost the page, i think its a 56mm, i need to find the page again
also, i thought i had to have a fmu to run turbo, how do i run it without one?
how many miles are on your camaro?
Originally posted by Fondle View Posthow do i run it without one?
Originally posted by Fondle View Posthow many miles are on your camaro?sigpic
1997 Camaro RS A4
2006 Chevy Colorado
Originally posted by Shodown View PostIm currently running 15 psi on 42 lb injectors. I ran 12 on 36's and they were maxxed.
TEAM C6V6
Originally posted by Fondle View Postwell im at 126k so i dont want to over boost
Originally posted by Fondle View Postdo you think a t25 is too small to run 8-10 lbs?
I would ditch it and get a proper size such as a 62-1, 60-1, or a t3/t4 hybrid.Last edited by Shodown; 03-18-2009, 03:20 PM.sigpic
1997 Camaro RS A4
2006 Chevy Colorado
