So I called around today with different shops , most wouldn't touch it because of liabilty issues even though I told them it is just a A/C line not a fuel line , I'm not going to blow up if it started leaking.LOL Found one place that would look at it, instead of me using a used hose , I decided to buy a new one since the one on my car is over 13 years old with 168,000 miles on it. So tomorrow or Monday since the shop might be closed I forgot to ask. I will find out if they will do it and have basicly no A/C hose 2 feet in the engine bay. I just want 2 90 degree bends so it goes straight up and down from the canister. It will so badass if they can do it and it works, so far $85 for new assembly and will see how much for the shorting it and doing some new PSI clamps on the lines. But they said they can't get to close to the original ones , thats where they might run into problems but even if it goes towards the radiator instead of the engine bay, it will be worth it. For us turbo guys and you powerdyne guys since you have to wrap that hose around the Powerdyne to get it to fit in the engine bay. Why didn't anyone think of this before? I'm 25% brain dead on the right side of my brain and I thought of it first. LOL if they can do it I will post some pics and the details on it.
Shortening A/C hose in engine bay
96' Camaro M5 to A4 conversion, alot of mods . GT35R Turbo full suspension. Built engineTags: None
Re: Shortening A/C hose in engine bay
If it didn't get 115-120 degrees here in the summer , I would of taken it out along time ago. Sounds like you just need a electric water pump and you could shorten it even more.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
There supposed to take a look at it for me and see what they can do. It is a A/C company. So well see. I took me about 15-20 calls to different places, most just said no and a few said they could but they wouldn't do to liabilty, so I finally found one that would look at it.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Went up and showed the guy what I want done, he said he can send it to his buddy and he could do it, said for me to mark what needs to be done and make a drawing of it ,so he has a better idea. I'm going to take a couple of pictures of it, how it is installed normally and mark on the hose then draw a diagram of how the new one should go. I'm going to drop it off Monday. I'll let you know how it comes out. This should be a good for guys wanting to keep their A/C's giving them so extra room with a supercharger and turbo.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by ssms5411 View PostThere supposed to take a look at it for me and see what they can do. It is a A/C company. So well see. I took me about 15-20 calls to different places, most just said no and a few said they could but they wouldn't do to liabilty, so I finally found one that would look at it.Robert - owner www.FirebirdV6.com/CamaroV6.com
Raven
I understood the liability, so I didn't sweat them about it, just said thanks for your time. I hope this guy can do it, I started to mark how it needs to go, the bottom needs a 90 degree up and the top needs to be turned alittle or bent straight and a 90 degree down then either a hard line or hose can be fitted. This would make it where it is up close about 2"-4" out. Better than almost 2 ft.LOL I'm just going to take the pics and make a diagram number each section and write what needs to be done. I hope he can figure it out from there, it will make it so much easier and I won't have to try and bend the line back and also worry about the turbo heat on it.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
I got everthing measured out took some pics and will going down tomorrow, wish me luck. This could help alot of us FI guys who would be interested. I'll keep you guys updated.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
I dropped the Hose off today and should be done tomorrow, they are cuttting the bottom metal peice off and redoing it so it makes a straight up bend. Should be interesting. I'll post a pic of it when it is done and hope to get it on this weekend.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
I didn't get a call yet , so I hope Mon., I told them take their time because it has to be functional, so.....08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
FYI napa can do those crimps you may be able to make your own just have to find the endswww.turbov6camaro.com
1997 3800 Series II Camaro
Originally posted by vr4gasm View Postcan i ask how much they are charging?Last edited by ssms5411; 04-12-2009, 01:04 AM.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
