help!!! pleases oil pressure gauge not working - FirebirdV6.com/CamaroV6.com Message Board
  • help!!! pleases oil pressure gauge not working
    after the supercharger install, the oil pressure gauge is not working
    any ideas on what the problem may bee??:bowdown::bowdown:
    headers, high flow cat, slp loudmouth
    powerdyne supercharger 6psi
    GT2 cam. all done by myself :banana:
    Hell yea
    Re: help!!! pleases oil pressure gauge not working
    Check the connector to make sure it's hooked up properly. You can also test the gauge by grounding one of the leads (not sure which one, you'll have to research that) but when grounded, the gauge should move to 0 PSI, I believe. If it does, you know the sensor is bad.
      it is. on the guide is facing downwards mine is facing upwards should this be a problem ???
      Hell yea
