I've recently installed a Powerdyne SC and I notice that after putting the car into boost I get a gas smell coming out of the gas cap area. I'm assuming that the gas tank might be getting pressurized through the evap. system.
Has anyone else had this problem?
If I drive the car normally, no smell. It only happens if I put the pedal down far enough to see boost on my gauge. Also my gas cap no longer makes a hissing sound when I take it off. I don't use an FMU and I have made no changes to the fuel system like a new fuel pump, I use HPTuners. There are no gas leaks that I can see and the only place that has a smell is inside the gas cap door.
Any ideas?
Bryan
Any ideas?
Bryan
