BOV with Powerdyne - FirebirdV6.com/CamaroV6.com Message Board
BOV with Powerdyne
  • BOV with Powerdyne
    What would be a good and inexpensive BOV for a 6-9psi powerdyne set up?
    I was thinking about getting these things.
    T-Pipe
    http://www.siliconeintakes.com/produ...f23f76de3b46a5
    BOV
    Thanks
    Re: BOV with Powerdyne
    both links are no good.
    All you need is a Bosch one from like a SAAB. It is a black plastic part. I scored a couple before off ebay for like 10-20 bucks. Work just fine
    http://www.bowtiev6.com/
      T-Pipe
      http://www.siliconeintakes.com/produ...c5d1cd6183b5ab
      BOV
        I think they will work now.
        If I get the bosch BOV should I use this pipe?
          Don't use bosch. I've gone to 3 of those already.
          It is plastic and the rubber diaphram in it rips easily. Even Saab owers tends to replace theirs with something else.
          I have Typhoon right now, but if I can do it over I would get the Greddy.
            I used a XS BOV with mine, sounded good when I had it. I think I paid like $100 for it.
              Well, I went ahead and got the one I linked. Ill let everyone know how it works Thanks for all the help everyone!
                I got an Ebay type S pretty much like the one you got. Give me a couple of days for some couplers to show up and I will let you know how it works too. :rock:
                  sweet I just say your post about your powerdyne. I cant wait to get mine going. I just need a bracket and bigger injectors and a few other little things.
                    ^ Yeah, a bracket would be handy. 97rs4life knows where you can get one ;). Its amazing how many little things I overlooked too, so be prepared for ordering/making trips to the store..lol.
                      For sure! I need to start a good list of everything I need. Know if there is a parts list out there somewhere?
                        • Mounting Bracket
                        • Powerdyne
                        • AEM Uego
                        • HpTuners Pro
                        • Extra O2 Bung
                        • 103 5/8” Belt
                        • 45* Oil Sending Relocation Elbow & 3/8 Plug
                        • Triple Gauge A-Pillar
                        • Autometer Ultra-Lite II Electric Fuel Pressure Gauge
                        • Autometer Ultra-Lite II 20Psi Boost/Vacuum Gauge
                        • 6# Smooth Pulley
                        • Valve Cover Breather
                        • 8 - 42# Ford Green Top Injectors
                        • Powerdyne Rebuild Kit
                        • New Throttle Body Gasket
                        • Type S BOV & 3” Adapter Pipe
                        * NGK Tr6 plugs
                        * Piping - two 3" to 4" 90* reducing elbows, one 3.5" to 3" reducing 90* elbow, misc 3" piping
                        * IAT sensor grommet
                        * Misc Vacuum Line and T-fittings
                        * Zip ties
                        * 180* Thermostat
                        * 3/8" Threaded hex plug
                        This is what all I got and all I can remember/know of right now. This is for a 97 bird with the angled TB. So if you have a straight TB your piping will be different.
                          The powerdyne has 3" inlet & oulet? Would there be a problem reducing it to a 2.5" piping? the pipe i got for the bov is 2.5". I was planning on doing 2.5" piping. Where did you get all your piping from? I was going to order mine from siliconeintakes.com (where I got my bov
                            The powerdyne has a 3" discharge and a 3.5" intake. I am not sure on 2.5 piping, I just went with 3" since the discharge was 3". I just bought a "universal intercooler piping kit" off of ebay that was 3". It came with lots of 3" tubing bent different directions and couplers and stuff. The reducing elbows I got from intakehoses.com. But you can get them wherever you want.
                              Damn!! Scratch the two 4" to 3" reducers. Turns out I just need three 3.5" to 3" reducers.
