Ok, so I got the powerdyne installed and everything, but have a strange noise. :cry: See video for noise.
Things I KNOW its NOT:
1. too loose/tight belt
2. impeller rubbing on casing (took discharge off and reset it, no marks on either impeller or housing)
3. Pulley hitting/rubbing anything
4. Nothing loose such as a spacer or mounting bracket
5. Bad bearing in the blower itself (I rebuilt it right before the install, AND when the blower is out and you spin it by hand it sounds fine.)
6. Piping hitting/rubbing anything
7. Every other obvious thing to check.
My thoughts are maybe a bad bearing in the ribbed idler that came with it, or something rubbing that I can't see...
ANY thoughts would be greatly appreciated. Thanks!!!!!
