Okay, I know it's not the motor- when it works, it works just like it did the day I put it in. So, every once in a while, the window will either stay down or up. Then, sometime later, it will start working again. I'm thinking it's either the switch or the relay. Anybody have the same problem? I do hear what sounds like the relay activating and the motor getting power, but I haven't had time to throw a multimeter on the leads to see what the voltage is.
Power window problem
Because the window will stop working for days/weeks at a time. Other times, it will start working again just hours later. And the motor moves the window the same as it did when I first put it in. The only thing throwing me off is the relay clicking and the power drain when I use the switch. I'm almost positive that the connection between the motor and the wires is good, as well2000 silver A4 Camaro<br />Whisper lid; Free Ram Air; BMR stb; MSD super conductor wires; Gatorback belt?<br />1986 RX-7 (daily driver)
I'm so stupid. I bought a new motor just to rule it out, and it looks like I'll be replacing it for a second time2000 silver A4 Camaro<br />Whisper lid; Free Ram Air; BMR stb; MSD super conductor wires; Gatorback belt?<br />1986 RX-7 (daily driver)
