Turn signal - FirebirdV6.com/CamaroV6.com Message Board
Turn signal
  • Turn signal
    My driver side turn signal doesn't work. I've changed both front and rear bulbs, checked the grounds and everything it fine. My passenger side works fine. I don't think it is the flasher relay since if that was bad, both sides wouldn't be working.. DO you guys know where or what to check next so I can fix this thing. Thanks
    1996 Firebird<br />Wolfgang Polish--the best<br />working on Project Phoenix
    Maybe the switch itself is bad?
    2000 GTP<br />Thrasher CAI, 3.4\" pulley, DHP PCM<br />Member RedLineVSix<br />Best ET-14.02<br />Best Trap-97.15
      My passenger side turn signal went out, then worked again a month later, and then went out yesterday. It was pissing me off, so I reached down, and with the car on, jiggled the front turn signal bulb around, and it works again. Give that a try.
      Andrew
