ok guys this is the last time i write this :D
for automatices here are the steps.
1.ignition must be in off position
2.restore battery terminal
3.turn off a/c controls
4.set parking brake and block wheels
5.start engine
6.shift tranny into d
7.let engine idle 10 min
8.turn a/c controls on
9.let engine idle 10 min
10.shift into p
11. let idle 10 min
12.turn a/c off
13.let idle 10 min
14.turn engine off 30 seconds
for manuals
1. same as above
2. same as above
4.same as above
5. put tranny in n
6.start engine
7.turn a/c controls on
8.let idle 10 min
9.turn a/c off
10.let idle 10 min
11.turn engine off 30 seconds
Thanks for the info. I thought that it was supposed to idle at 1000 rpm also, because my old Mustang GT did. Just found out that it was supposed to be 700-something.
<b>1998 Firebird 3800 Series II, A4</b><br />Direct-Flo Lid,K&N Filter,DEE TB Spacer,TPS-TEC,ZZP Mini-AFC,Raised and Cutout Airbox 7mm,BMR STB & Boxed LCAs,KYB AGX Shocks,Drilled/Slotted Rotors,180* Thermo,2.5\" Catco Cat,Dynomax 2.75\" custom catback,Kumho Ecstas/245,Jet Stage 2,3.42,Edge Racing 2870 Stall,B&M Tranny Cooler,B&M Deep Tranny Pan,LSD,AAM Girdle,1LE DS,NX Wet Kit,MSD DIS-4,MSD Blaster Coil Packs,Taylor Spiro Pro 8mm Wires,NGK TR6\'S gapped .045,ZZP UD WP Pulley,SLP Fan Switch,TT II\'s<br />N/A: 15.6342 @ 88.44 (On stock converter. Strugglin\' to beat it.)<br />Nitrous 50 Shot: 14.7463 @ 93.49
mine idles at 1000, too. and i can't find anywhere in my chilton's what it's supposed to idle at? anyone know?
95 Med Quasar Blue Camaro M5<br />-free ram air scoop<br />-removed silencer/cut airbox<br />-slp air temp module<br />-tb bypass<br />-160* thermostat<br />-underdrive pulleys<br />-installed my own t-tops! best mod yet!
<blockquote>quote:</font><hr>Originally posted by TheCardinal: so the PCM screws up on occasion causing the IAC to change the car's idle??<hr></blockquote>
My idle would drop to 0 and jump to 1500 and down to 500 and so on. The solution was to remove the IAC from the TB (throttle body) and clean it really good with carb cleaner. Push the pintle in so you get the clearance needed when reinstalling. This solved my problem.
Since this is part of the fuel system you might suspect other components are dirty. It's a good idea to clean the TB itself by spraying carb cleaner into it. I noticed improvement from this as well.
I also decided to pour in a bottle of Slick 50 fuel system cleaner to see if it would help.
Check inside the airduct for cleanliness, if it is dirty, you may want to clean this too.
the IAC is part of the fuel system? how do you figure? Fuel doesn't run through it. the only connection to the fuel system it could have is that the computer controls both the IAC and the fuel injectors.
\"If we can put a woman on the moon, why can\'t we do that with all of them?\"
<blockquote>quote:</font><hr>Originally posted by SuperRat: My idle would drop to 0 and jump to 1500 and down to 500 and so on. The solution was to remove the IAC from the TB (throttle body) and clean it really good with carb cleaner. Push the pintle in so you get the clearance needed when reinstalling. This solved my problem.
Check inside the airduct for cleanliness, if it is dirty, you may want to clean this too.<hr></blockquote>
[ August 20, 2002: Message edited by: The swede ]
[ August 20, 2002: Message edited by: The swede ]</p>
