seat bolt - FirebirdV6.com/CamaroV6.com Message Board
seat bolt
  • seat bolt
    What is the size of the nut that holds the seat in place. I took out my seats but seemed to have lost one bolt.
    Thanks
    EZD<br />1996 Camaro <br />K&N FIPK<br />Borla 3\" Exhaust<br />Dynomax 3\" Cat<br />Panasonic Ghost CD Player
    If memory serves, it's a 10mm or 12mm I think. I took out my rear seats and I believe I used one of those most of the time.
    <br /><br /> <a href=\"http://www.cardomain.com/id/nitroxxx28\" target=\"_blank\">http://www.cardomain.com/id/nitroxxx28</a>
      13mm.
      -Marc
      [ March 26, 2003: Message edited by: hockeyman ]</p>
        I used a 13mm wrench to get it out.
        jsut take off another and take it ot home depot, they have a thing itn the nuts and bolts section that you cna screw your nuts or bolts in/on and see what size they are, jsut do not force it [img]smile.gif[/img]
          also I am pretty sure its a fine thread.
            I went to Canadian Tire and Home Depot and they only have there nuts measured in inches. They are retarded over there.
            • Andy H
              Transmission removal help!!
              by Andy H
            • 2.8 Bird
              Abs inop
              by 2.8 Bird
            • fishin
              by fishin
