I'm getting some significant engine chatter that I can hear when the hood is shut. It sounded like maybe one of the pulleys was going out, but I took the serpentine belt off and fired the car up for a couple seconds and still heard the sound so its not any of the pulleys, so it must be internal noise. What could cause a chattering noise like this? Thanks
Engine chatter
Re: Engine chatter
Originally posted by 99BlackW68 View PostI'm getting some significant engine chatter that I can hear when the hood is shut. It sounded like maybe one of the pulleys was going out, but I took the serpentine belt off and fired the car up for a couple seconds and still heard the sound so its not any of the pulleys, so it must be internal noise. What could cause a chattering noise like this? Thanks
Re: Engine chatter
bad crank balancer, Hows your oil? what side of the engine is it? How many miles on your car?08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: Engine chatter
It could be any pulley under there. Try using a piece of hose or a mechanic's stethoscope to listen around and pinpoint the noise.2002 Silver Firebird A4<br />T-Tops, Leather, Y87, W68, Chrome Wheels<br />Bone Stock
Re: Engine chatter
its an automatic, i cant tell which side of the engine its comming from, i said i took the belt off and its still there so its not a pulley, the sound stays with the hood open, 86k on the car, the oil is fresh and is changed every 3000 miles.
any ideas guys?
1999 Firebird Y87/W68
Re: Engine chatter
Could be a dry rotted crank balancer, thouhgt mine was a rod at first but after taking the belt off and doing some research it was my balancer that had dry rotted from the inside and was out of wack, $100 later running smooth again.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
