My car is at my buddies because he has a garage and i dont. He has become very busy so working on my car has been non existant recently. well he had my car is his side garage and i guess the moisture is what caused the rust but on each head port where the headers/ exhaust manifolds go there is rust, my question is, does this just completely defeat the purpose of me having the heads polished like they are? will the rust affect performance or gas mileage, or will it burn off once the car is fired up? Does anyone think the inside of my motor is rusted as well?
supersix powerpack and rust everyone please help
Longtubes, true duals, ram air, caspers tps tec, ls1 26lb injectors, supersix powerpack, heads milled .020, comp cam .507 220/224 114 ls, forged internals and chromeoly pushrods, bored .030 over, tb spacer, tranny built with stiffer springs and kevlar bands, bigger servo, transgo stage 3 shift kit, edge 3600 stall, 1 pc aluminum ds, 3.73 superior gears, lsd rear ,custom pcm tuning, walbro 255 in tank,Tags: None
tttLongtubes, true duals, ram air, caspers tps tec, ls1 26lb injectors, supersix powerpack, heads milled .020, comp cam .507 220/224 114 ls, forged internals and chromeoly pushrods, bored .030 over, tb spacer, tranny built with stiffer springs and kevlar bands, bigger servo, transgo stage 3 shift kit, edge 3600 stall, 1 pc aluminum ds, 3.73 superior gears, lsd rear ,custom pcm tuning, walbro 255 in tank,
