My passenger side t-top squeaks, all the time, no matter what speed. I tightened all the bolts, banged on it, yelled at it, everything I could think of. Any ideas on what I could do to tighten up the problem area?
I searched and all I came up with was leaking t-tops.
I'm going to try and explain this the best I can. If you take off the cover on the 'A' pilar where the T-Top attaches (also on the sail panel) you'll see the hole where the T-Top attaches with it's rod. The hole should have (on front and back) a little plastic gromet that sticks in there ... mine squeaked (metal on metal) until I got replacements 'cause one was MIA. Just food for thought.
My passenger side t-top makes a tapping/ticking sound only over bumps. It's gotten worse and it's really annoying. I don't know if it's the same noise that's being talked about here or not. The only thing that helps is wrapping the pins that stick into the car with electrical tape. I have also read on ls1tech.com that the rivets inside the t-top on the linkages get loose and make the noise, which may be my problem. The only fix is to take the plastic cover off of the t-top and cram it with foam. I have been dealing with this for a year and all of these fixes seem temporary at best.
1999 Y87 Camaro<br />Whisper Lid, SLP SS Takeoff Exhaust
Everything was fine when I took the plastic off the a-pillar, so I put tape around the pins like silver 99 camaro said. I just took a quick spin around the block but it looks like that might have done the trick.
Thanks again guys, that thing was really getting annoying.
So went out to start the Camaro and no start, batteries are good just hear a thud sound, started up fine last Friday. Check the fuses and the battery...
Working on getting my 99 Camaro back in action. Long story short, got parked in the garage about 5 years ago (kids, career stuff ect.) trying to get her...
Well, I finally am getting some time to get back into these cars. Today I installed a set of no name eBay stainless headers that I’ve had for probably...
