** Edit: This is for a 1999 Camaro 3800 with Y87 package. Engine has been replaced, new engine has roughly 60K on it. **
So I noticed I had some coolant around the water pump. It seems to be behind it and above. Almost sorta like it's the lower intake manifold. Which explains why I've been adding coolant slowly the last few days to the radiator.
At first I thought the water pump was leaking through the weep hole. But even with a new water pump from Oreilly's the leaking continues.
I am worried it's the intake manifold upper/lower. However my oil is lightly brown & clear (fresh synthetic) so I'm fairly sure there is no internal leak going on. There is no smoke or anything from the rear. I'm going to try to get some clear pictures tomorrow.
What do you guys think it might be? I keep searching the forum and keep seeing references to 90 degree elbows that are prone to leaking. I can't really see them now at night. Where might I find such a part (oreilley/napa/autozone seems to not list them)?
If it is the intake manifold gasket how reasonable do you think it is for a relative novice to do the job? I replaced the water pump in roughly 30 minutes. It seems like for the intake manifold you need to remove fuel rail, injectors and the coil packs. Then it seems like a straight up unbolt and pry open job. Am I missing anything?
Thanks in advance!
Thanks in advance!
