Zmax - FirebirdV6.com/CamaroV6.com Message Board
Zmax
  • Zmax
    what are your thoughts on this product? i am temped to use it just wondering if anyone else has and if its worth the 35$
    2001 Camaro 3.8 A4
    1991 3000GT VR4
    2001 Mitsubishi Eclipse GS
    Re: Zmax
    Tried the whole system a few years ago... can't say if it worked or not, I didn't notice any good or bad...
    I will say that I tore my engine down within a year of using that, and my valves and pistons were still pretty filthy... but that could've been build-up from all the time it ran after I used it...
    Custom interior...
    TEAM NoVa
      Re: Zmax
      i hear its bs.
      Follow me!
      Or this
        Re: Zmax
        yah i have been reading reviews online i will waste my 35$ on something else
        2001 Camaro 3.8 A4
        1991 3000GT VR4
          Re: Zmax
          you have to use it over time to see a clean engine. if you have ever watched power block they say that it takes time for the chemicals to clean the actual pistons and what not.
          My father first started using it about a year ago on his 04 dodge dakota 4.7l that he drives to and from work 60 miles each way. the first time he used it somewhere around 75k miles he noticed right away a difference in throttle response and 1mpg increase. according to his overhead display. ever since then he swears by it and uses it with every oil change. since then i started using it and i personally haven noticed any difference however i have alot less milage then he does( 60k as of yesterday) on the car so im assuming jus less build up.
          again as far as cleaning the engine completly it would probably take years especially on a car that already has age on it.
          but i look at it as a less corrosive version of seafoam that cleans the injectors and fuel lines.
            Re: Zmax
            I had a minibike and I used the whole treatment on it I saw some improvement. But that was a 1 piston engine.
              Re: Zmax
              my oil changes already cost 60 plus dollars i don't need to add another 35$ to that oil change everytime lol
              2001 Camaro 3.8 A4
              1991 3000GT VR4
                Re: Zmax
                never said u had to
                  Re: Zmax
                  holy crap what are you using melted down gold?!
                    Re: Zmax
                    5 quarts of royal purple 8.99 @ local autozone
                    k and n filter 13$
                    2001 Camaro 3.8 A4
                    1991 3000GT VR4
                      Re: Zmax
                      holy crap. i did royal purple once and it only ran me $40. are u buying 5 quarts individually?
                        Re: Zmax
                        yah it took a price jump not too long ago i need to start buying it at jegs since i drive by there pretty often lol save me about 10 bucks or so
                        2001 Camaro 3.8 A4
                        1991 3000GT VR4
                          Re: Zmax
                          yeah probably not a bad idea
                            Re: Zmax
                            the best motor clean if that what ur looking for is a good 80mph highway drive for like 50miles and i ve tried z max and didnt notice a difference im sure it did but just changing ur oil and doing what ur supposed to will save ur motor
                              Re: Zmax
                              you could always just tear it down and clean it regularly....haha
                              • Andy H
                                Transmission removal help!!
                                by Andy H
                              • 2.8 Bird
                                Abs inop
                                by 2.8 Bird
                              • fishin
                                by fishin
