Popping from EGR? - FirebirdV6.com/CamaroV6.com Message Board
Popping from EGR?
  • Popping from EGR?
    OK the car has been sitting awhile. Im noticing a popping noise that seems to be coming from the exhaust manifold, closest to the EGR.
    My question is; WTF?
    98' Camaro M5
    Re: Popping from EGR?
    Anyone?
      Could it be that the connection to the EGR on the manifold/header may be loose/leaking?
        Maybe a burned plug wire?
          Quite possible. Ill check to see how tight it is. I deff heard some noise in that area, I just didnt know whta it was. Seen smoke come out of there too. Could a clogged line cause that?
            It could also be that the valve itself went bad, but let's do the easy stuff first.
              exhaust leak maybe? I had some popping when my header bolts were loose.
              1998 Chevy Camaro 3.8
              1997 Chevy Camaro Z28 - SOLD 7-23-2011
              1996 Chevy Camaro Z28
              2001 Pontiac Firebird Formula
                As in electricity arcing from a plug wire will make a ticking noise.
