Okay this is starting to drive me nuts. I have manual door locks and with any kind of bass they both vibrate like crazy. The pass side lock is bad enough that its noisy when just driving around, forcing me to lock it to silence it. The drivers side is still noisy unless I happen to have my arm against it. So is there any way I can fix them? Or something I can jam between the lock and door to keep it quiet?
Vibrating door locks
I had the same problem. I have auto locks, but it should be the same. nobody knows how to fix it. So what I ended up doing was taking the plastic piece off. unlock the door, pull up and toward the front of the car. its sort of hooked on there so you have to pull up to get it unhooked and to the front to pull it out.
Then I had some velcro laying around. I put the softer of the 2 velcro pieces on the back side of the plastic locking piece. Then put it back together as tight as I could.
When you take it off you'll notice that GM put some sort of velvet or something on there in the first place. but the velcro is thicker, which does make it harder to move. but it will wear down.
Anyway, thats what I did. I wont guarentee that it'll work, but I had the same exact problem and thats what fixed mine.
by DongrossmdI’m new. I actually don’t own a Camaro or firebird. I do have a 2000 Camaro 3.8 fly by throttle and 4l60e. This is installed in a 1980 Triumph TR7...22 hours ago
