People with DIS-4, launch RPM question! - FirebirdV6.com/CamaroV6.com Message Board
  • People with DIS-4, launch RPM question!
    Aite, its installed and the car is running great. Anyway, i was setting up that launch RPM thingy that teh box has, and i have the wire run into teh car, the ground was properly setup, and i had a momentary switch setup. My problem is that with the switch hooked up, the car wouldnt go beyond my launch RPM of 3250, and with the momentary switch pressed in (which SHOULD have completed the ground loop), i could rev normally.
    Basically what im asking:
    ***Where did you get your momentary switch that is normally closed?***
    cause the one i got, despite it saying "Normal Operation: Closed" on the box, its definately an open loop until you press the button.
    Honestly, who needs a switch thats always on until you press the button, then you let go and its on again. I can think of no good use for it.
    6 days ago
