Fuel Pressure - FirebirdV6.com/CamaroV6.com Message Board
Fuel Pressure
  • Fuel Pressure
    Before I replaced the head gaskets I ran a fuel pressure test on the 97. The readings were a little odd to say the least but I figured I have bigger fish to fry so I would leave that till later..Well it is later. I am hoping that I can gain a little insite on this. Here is the progression of things
    1: Connect Fuel pressure guage to fuel rail.
    2: Turn key to the "ON" position
    3: Fuel pump starts
    4: Fuel pressure builds to about 34 Lbs (about normal)
    5: Fuel pump stops running (normal)
    6 Fuel pressure drops to 0 Lbs (NOT NORMAL)
    If I start the car (has to crank till fuel pressure is buildt back up). The fuel pressure stays about where is should.
    Any ideas? Is this a fuel return problem, a fuel pump issue? I did visually inspect the injectors when I had them off and they (looked) fine.
    HELP
    Thanks as always.
    Remember that sometimes, silence is the best answer.<br />Warren White<br />1996 PoloGreen Coup <a href=\"http://vampyr.settanni.net/\" target=\"_blank\">http://vampyr.settanni.net/</a> <br />\"Jealousy\"<br /> CTFBA member of the month Sept 03
    Re: Fuel Pressure
    as im not very good with fuel injected cars, i would have to say take a look at the fuel pressure regulator, it may be bad, and is just letting the fuel drain back
      Re: Fuel Pressure
      I agree, that's a classic symptom of a bad FPR.
        Re: Fuel Pressure
        i would guess the fpr
          Re: Fuel Pressure
          FPR, or the hose on your fuel pump is not all the way on.
            Re: Fuel Pressure
            OK so is it a possibility that this would cause a low/rough idle as well?
              Re: Fuel Pressure
              I had a bad FPR, did the same thing to pressure, caused hard starting when it was warm, too rich, and a misfire.
              Mine was leaking fuel into the vacuum line. Found it by taking off the vacuum line while running and could feel fuel coming out.
