changed the fuelpump and filter flush all the fuel lines out what to do next
still will not run
Re: still will not run
Check the pressure at the fuel rail. If there's good pressure, next check for spark. If there is pressure and spark, then you need to ensure the injectors are working. For that you need a voltmeter or a test light. Hook the leads to the wiring harness and crank the car to see if power is getting to the injectors. You only need to test a couple of them, because even if only a few work, it will run...just like crap though. Remember... no start conditions are either no fuel or no spark.2002 Silver Firebird A4<br />T-Tops, Leather, Y87, W68, Chrome Wheels<br />Bone Stock
could also be no air. Make sure there is nothing constricted in your intake and that your MAF is hooked up. I've actually seen a car that had the sreen blown to pieces and the intake melted that caused the car not to startCar expresses who you are. If you have a ****ty car, you must be a ****ty person;)<br /><br /><a href=\"http://www.cardomain.com/ride/995979\" target=\"_blank\">http://www.cardomain.com/ride/995979</a>
X2 on codes, another thing is #1 injector is bad , if so it will not start, I had that problem before. So further info needed.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
One of those hoses/clamps on the fuel pump assembly may have come loose while you were fixing it. Others have had that problem, and I did too when I replaced a fuel pump on an Astro years ago. So you'd have the pump running, and a little pressure..... but not nearly enough to run the car.2002 Silver Firebird A4<br />T-Tops, Leather, Y87, W68, Chrome Wheels<br />Bone Stock
