96 3.8 camaro coil bracket - FirebirdV6.com/CamaroV6.com Message Board
  • 96 3.8 camaro coil bracket
    If anyone has any pictures of the backside of the engine where the coil bracket bolts to the block, could you please post up some pictures, my coil bracket was completly busted and just sitting on the valve cover vibrating when i bought it causing random misfires
    so i bought a new coil bracket, but cant reach behind to find the damn bolts to unbolt the broken bracket so i can install the new one
    Re: 96 3.8 camaro coil bracket
    bump, noone has a pic of there 3.8 pulled that could get me a pix of this?
      my 3.8 is in my fathers driveway, i'll stop over there tonight and see if i can snap a pic for you.
        There isnt a bracket on the back of it. There are two holes going straight down behind the coils, and one on the front that goes thru the engine lifting bracket. The three silver rings you see are the mounting points.
          im sorry abou that, thats what i was referring to (lift bracket) since its the piece thats bolts behind the engine to the block, when i was searching and looking on ebay for a new one, they just had both pieces labled as coil mounting bracket
            The lift bracket blots to the Front between the EGR valve and head on the drivers side and holds the coil bracket.
              do you need a pic of what it looks like or where it bolts to, cause i can see you are getting no help.
              Team NoVa
                He's getting help..
                BTW, there are only 2 lift brackets. The front driver side and rear passenger.
                TEAM C6V6
                  the bracket that the plate bolts to, it goes behind the driver valve cover and bolts to the block i believe, but when i reach back there i cant find where at (even with the old broken piece still back there i think)
                  so i wanted/needed a picture of were it bolts up to back there, so i have a idea were i need to reach for.
                  but im thinking it might require the upper intake to be pulled off most likely but not sure...
                    no you dont have to pull the intake. sorry i have been busy, ill get you the pic so you can see, i have the heads off the car so i can get a pic of it.
                    Team NoVa
                      i understand busy, whenever you get a chance id apperciate it
                      thanks
                        again, sorry it took so long, i had a death in my immediate family. here ya go, i took a couple so i hope it helps.
                        Team NoVa
                          thanks for the pics, that helps alot!! i was thinking it went further back, so i wassnt even in the right spot, thanks again! and sorry to hear, my prayers will be with ya
                            glad i could be of service to you sir! and thanks for the prayers man.
                            Team NoVa
                              Hey that's good info for me too. I didn't even know it was a bracket assembly like that. That'll definitely help when I eventually get deeper into my engine.
                              TEAM C6V6
