wires were bad but after changing them things got bad now it is missing horribly and popping through the exhaust and intake tracked the miss down to cyl no, 3 injector is good plug is good but the car can barly pull itself
any info will help
1995, 3.4l, v6 automatic, no pcm mods, no cat turbo thrush muffler, dry 100 shot of nos(ended the life of the car befor its time), cai, T.B. heater bypass,
o i also am very sure the firing order is right also it is a 3.4 1995 auto
Make Sure all your wires on on tight and that your plugs are gaped correctly. firing order just to be sure is
P Back D Coil order P 2 D
5 6 146325
3 4
1 2
Front
And check all your vacume lines
