Changing Oil Pan - FirebirdV6.com/CamaroV6.com Message Board
Changing Oil Pan
  • Changing Oil Pan
    Hey. I had a run in with a rock on the highway and now I need a new oil pan. I was wondering if there was any other way of swapping the oil pan besides lifting the engine. I do most of my work in a parking lot and I don't really have access to a cherry picker to lift up the engine. I read that dropping the cross member might work, but I was wondering if anybody had done it this way.
    i have done it both ways with a 3.8 and both being manuals but it was on a lift. if you have an auto, expect it to be harder cause the flag time if i remember correctly was almost an entire hour longer. if i was doing it in a parking lot, i would definatly lift the engine. besides, all you need to do is lift the engine tranny assembly with a jack stand. good luck buddy cause its going to take atleast the better part of the day doing it on the ground.
    2000 3.8 A4 Pewter Camaro
      So, I should be able to use a jack and a block of wood to lift up the engine if I place the block and jack between the tranny and the oil pan right? I just need a few inches so I'm sure nothing needs to unplugged or removed besides the engine mounts right?
        Im going to tell you the nicest way i can.... you cant do it your self in a parking lot unless your superman...take it to a shop. You have to remove transsmission, starter, unbolt the engine and raise it up a few inchs. Its no fun.
          i have some pics on my site...i have more i need to add also.
            This wont help, but the shop said they dropped my exhaust.
            Red 1998 Camaro<br />Mods so far=<br />K&N
              When my mechanic and i dropped my exhaust to remove the pan the 2 of the 4 bolts snapped off..we had to drill and tap...sucked
                Thats probably just the Y-pipe.
                1997 Camaro Y87. Turbo.<br /><a href=\"http://pureoctaneracing.net/\" target=\"_blank\">Pure Octane Racing</a>
                  Anything is possible man. Removing the transmission and starter isnt that hard. You just need some way to keep the engine from falling on you.
                    drop the y-pipe down, you do not have to unhook the tranny, thats just adding a crap load of trouble, unbolt and remove the starter, unbolt the engine from the mounts, unbolt the tranny from its mount( not the engine ;) ) and lift. read the guides and get a manual. it can be done, some people are just dont have the brains and balls to do it
                      ;) Ok, seems every one dissagrees with me, but thats ok. Make sure you come back and let us know how it turned out. Because i already know how its going to turn out, "brains and balls" as mr gm tech put it has nonthing to do with it. Save your self the trubble and waste of time buddy.
                      [ February 15, 2006, 11:07 PM: Message edited by: BobbyZ72 ]
                        Have you even ever replaced one? brains and balls have everything to do with it obviously because you dont have the brains to know what is required or the balls to try it yourself. also, dont try to insult me with my profession
                        [ February 15, 2006, 11:24 PM: Message edited by: BLLDOGG ]
                          Hmm.. you think its not possible don't you? Anything is possible if you have the brain and balls to do it. I've seen 3 guys put a new motor on a 240sx without a use of cherry picker or anything. They just used a pole and chains to lift the motor out(one guy on the each end of the pole with the pole on their shoulder lifting the motor up, while one guy guided it). If you are a car enthuasist on a budget, you will think of a way to do stuff without the use of expensive equipment.
                            My thoughts exactly ... I did my oil pan and never touched or even thought about removing the tranny ... Don't need to at all.
                            \'97 Firebird 3.8 ... 1/4 mile = 12.50 (minutes)
                              [/qb][/QUOTE]Have you even ever replaced one? brains and balls have everything to do with it obviously because you dont have the brains to know what is required or the balls to try it yourself. also, dont try to insult me with my profession [/QB][/QUOTE]
                              Yes i have replaced mine, did it with me mechanic. Took a car lift, transmission jack, and removing my old rusted one exhaust, raising engine and about 5 hours. Its not something your going to want to do laying on your back unable to move in your drive way. OH AND MISTER BIG SHOT GM TECH, I WAS NOT TRYING TO INSULT YOU! YOU INSULTED ME SAYING I HAD NO BRAIN OR BALLS!
