Changing Oil Pan - FirebirdV6.com/CamaroV6.com Message Board
Changing Oil Pan
  • #16
    I was insulting you, you and me mechanic
    dont get your panties in a bunch cause your very wrong and not very helpful in supporting him to do it himself and save a lot of money. you must be one of those people who thinks doing headers and exhaust in your driveway isnt possible to do easily too huh?
    The whole point of this board is to help and encourage people to do work themselves, not "O' it's too difficult, take it to a mechanic who will charge you 75bucks an hour".
    [ February 16, 2006, 08:39 PM: Message edited by: BLLDOGG ]
    2000 3.8 A4 Pewter Camaro
    • #17
      yea, it is possible to change the pan on the ground, just alot harder.
      • #18
        I havent read anyone mention anything about having to remove your upper intake, and possibly your heads. This would give you enough clearance to safely raise you motor enough to remove your pan. Otherwise the top end of your motor will ride your firewall.
        ---94 Camaro-L32--- <br />\"Don\'t hate the playr, Hate tha GAME!!\" <a href=\"http://members.cox.net/jeanda_sd/SD_L32/SD300L32.jpg\" target=\"_blank\">http://members.cox.net/jeanda_sd/SD_L32/SD300L32.jpg</a> <br /> <a href=\"http://members.cox.net/jeanda_sd/SD_L32/100_0022.JPG\" target=\"_blank\">http://members.cox.net/jeanda_sd/SD_L32/100_0022.JPG</a> <a href=\"http://members.cox.net/jeanda_sd/SD_L32/L32flipmode.wmv\" target=\"_blank\">http://members.cox.net/jeanda_sd/SD_L32/L32flipmode.wmv</a>
        • #19
          i didnt look at the clearances but i would think that if you go and take off the intake or heads, you would just hit your tranny on the bottom of the car before you reach the bottom intake and especially the block. if you do this, you are just adding a lot of extra problems that is not needed.
          • #20
            My $.02 BLLDOGG is a GM Tech. End of story.
            Black \'94 Trans Am A4- SLP CAI & Loudmouth<br />Red \'93 Firebird A4- Ram Air under the WS6 hood, !cat, exhaust.
            • #21
              Thank you Fbody3400. It's not just that I'm a GM Tech, it's that I have done this before.
              • #22
                I wish that ur "2-cents" ment something to me, nor has no value to me, but the fact still is...."he didnt look at the clearance"
                • #23
                  Fine dude, your opinion is your own and so is your time and money.
                  • #24
                    Well i wish that your reply made any sense, seeing as BD has stated already that he has done this. Fbody3400 Out. haha
                    • #25
                      I've just replaced the gasket on my pan bout 3 months ago, with no help, and using "no" hoist!. The clearance issue was one of the things i've encountered as I raised the engine! So i GUESS i've done this b-4, ALSO!! but, hey that doesnt matter right! cause I was just offering some info(from experience) that i noticed wasnt mentioned.
                      ...AND-FOR-GOD-SAKE, WIPE YOUR NOSE...YOU GOT "BROWN" ALL OVER IT!!
                      • #26
                        What ever guy, i am one of the last people around here that gets their *** kissed. well since you say you have done it, then you must know that it isnt neccassary to do it unless, well, you did go ahead and take yours off.
                        • #27
                          Well then "Einstine", i guess this means they've finally reached the end of the line for kssn-@ss. Cause if that is'nt it, then I dont want to imagine your idea of it is [img]graemlins/slap.gif[/img]
                          • Manimal
                            Coil springs
                            by Manimal
                            6 days ago
                          • Manimal
                            Newby here
                            by Manimal
