Harmonic Balancer removal...... - FirebirdV6.com/CamaroV6.com Message Board
  • Harmonic Balancer removal......
    As I'm sure most of you have taken off your harmonic balancer for what ever reason, I would like to know how and what are the best methods and tools that you used?
    and is there any special way of getting it back on??
    thanks a lot
    Re: Harmonic Balancer removal......
    need a pulley puller to get it off, as for installing it, no special tools, just line the key up and press back on
    http://www.bowtiev6.com/
      What about a tourqe wrench and breaker bar?
        might need a breaker bar to get the crank bolt out if it is an older car. no need for a torque wrench
          Well it is a 98 camaro RS 3.8....
            Also do I REALLY have to take out the starter in order to take the harmonic balancer off??
              i wouldnt think so, you just need to find a way to get the engine to not spin while removing/installing the bolt
                Ok, That's what they said at autozone.com..... But I would rather ask you guys anyways...
                  i usually just jam a big flathead screwdriver in the flywheel and that works fine
