i need as much info as u can give me for tune up basics and what is the best stuff to put on my 95 cam 3.4 from spark plugs/wires as much as u know
basic tune ups
All fluids, oil, transmission, coolant, power steering, windshield washer fluid, maybe flush the brakes.
Air filter
Check serp. belt
spark plugs and wires
check hoses
tires (rotate and fill if needed)
I usuallly clean my battery terminals
fuel filter is a good replacemet if you really want to get into it
As far as what is the best stuff, that is mostly personal opinion. However, I use AC Delco plugs, valvoline oil, and for the rest of the fluids I just get whatever isnt completely expensive.
[ February 12, 2006, 03:23 PM: Message edited by: SilverBirdSeven ]1999 Firebird
Above....^^^ plus Turn rotors, coils, grease fittings, maybe 4 o2 sensers, and maybe shocks and struts. The fuel filter and air filters should be number one on your list, they are easy to do and cheap. After that i would drop transmission pan and change filter, of course refill with fresh fluid.<a href=\"http://www.cardomain.com/ride/2245261\" target=\"_blank\">http://www.cardomain.com/ride/2245261</a> Green 1997, 105k, all stock except for Z28 front springs, Air shocks in the rear, home made coolant recovery tank, home made battery hold down.
by DongrossmdI’m new. I actually don’t own a Camaro or firebird. I do have a 2000 Camaro 3.8 fly by throttle and 4l60e. This is installed in a 1980 Triumph TR7...22 hours ago
