In the morning when I start the car up the vibration from the idling causes a rattling noise that is coming from the rear. It's a constant rattle until I put the car in drive and then I only hear is occasionally when I hit a bump or something. The rear end in general feels very weak when I hit bumps in the road. Any ideas? Could this mean my struts/shocks are going bad? Loose exhaust? I checked the exhaust to the best of my knowledge and everything seems to be secure.
Rattling noise coming from the rear end.
Re: Rattling noise coming from the rear end.
id check your shocks and struts something may have come loose and rattling around a bit, either that or the exhaust might be loose. I had that problem when i first bought my camaro in 06, the exhaust was rattling around sooo bad and something kept hitting the bottom of my car everytime i went over a big bump hahah. Do you hear any rattling when you slow down to a stop at all?Robby
2001 Chevrolet Camaro 3.8 V6
|JET Chip|Flowmaster American Thunder|K&N Intake|BMR STB|Spohn Rear Sway Bar|
http://speed-bros.com/
Originally posted by vr4gasm View Postback it up on some ramps start it up and get under there..
Check to make sure all the bushings are in good condition. Also check the exhaust hangers. There's a mount insulator for the hangers that tends to go bad and cause noises on bumps.'99 Camaro
'04 Saab 9-3 Aero
'90 Audi Coupe Quattro
yep...you can check your rear sway bar end links to...one of mine have snapped before...that could cause it...could also cause the rear to feel a little weirder...exhaust shields are famous for making rattling sounds as well.
