Ok guys, I need to replace the fuel pump in my 97 3.8 car. Book says to drop the axle, etc, which seems like alot of trouble, and I dont have the facilities for this. I have heard of people making an access hole to get to it. Any truth to this? Any advice or pics? Thanks in advance.
Fuel pump replacement on 97 3.8
Re: Fuel pump replacement on 97 3.8
yup, access hole is the way to go. I did it on my 97 years ago when I went with a walbro pump. Screw dropping the axle. ha
http://forum.camarov6.com/showthread...door+fuel+pump
There is a couple of write ups on it. You will find 2 in post #17. I used the second of the two.
Originally posted by 97rs4life View Postyup, access hole is the way to go. I did it on my 97 years ago when I went with a walbro pump. Screw dropping the axle. ha08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
