Waterpump replacement? - FirebirdV6.com/CamaroV6.com Message Board
  • Waterpump replacement?
    So is it hard to change one of these badboys on the 3.8?
    Past Ride
    1995 Firebird A4 3.8 Turbocharged -- 12.50 at 108
    (If you dont know me, you haven't had a V6 long enough)
    Current Ride
    2006 Mitsubishi Evolution GSR
    www.myspace.com/shane1015
    For a normal person, no. For you, set aside a weekend ;)
      Where about in FL are you?
        Only thing that would make it "hard" is you have a turbo in the way ;) Otherwise its very easy.
          shane, it took me 25 minutes to take the old one off and put teh new one on, and that includes coolant changing.
            "These badboys" are extremely easy to replace the most difficult part will likely be removing the old gasket.
              ya Id have to take my turbo off and thats no fun :( o well....i think my water pump is either not working up topar or my radiator is clogged.....ill do some more investigating.
              Past Ride
              Current Ride
                shane..im having sorta same trouble..only i locatedmy problem...my water pumps weep hole is leaking water..so bad that withing 2 hours all the water will drain out and it will over heat..teh water pump on the 3.8 is a matter of taking off 4 bolts (easier if belt is left on)then take belt off and teh pulley and unscrew all 6 bolts..2 different sizes..can't recall the 2 sizes..but once its out you may want to take a razor and scrape the old gasket off and get a new one..why do i get the feeling this is some sort of joke.. if it is haha, jokes on me. if not then good luck with teh water pump...also if any of you know how to take the pump fan off the water pump that would be awesome to know
                Kris
                ----------------------------------<br />|Factory Freak?|Stock|<br /><br /> <a href=\"http://img78.photobucket.com/albums/v258/NoRiceInside/ProjectCamaro/krissig.jpg\" target=\"_blank\">http://img78.photobucket.com/albums/v258/NoRiceInside/ProjectCamaro/krissig.jpg</a>
                  Kris
                  wtf, this post is 3 months old. [img]graemlins/stickpoke.gif[/img]
                    Yeah, but when people post, you always tell them to do a search. WTF? :rolleyes:
                    Also. what do you mean by this KrisXPC:
                    Jordan<br />15.09@90.7<br /><a href=\"http://www.fullthrottlev6.com/forums/vbgarage.php?do=view&id=21\" target=\"_blank\"><b>1995 Camaro 3.4 M5</b></a>
                      i want to replace the gaskets and seals.. hear its to hard to do in a garage..any who but there is no bolts or any thing on eitehr side
                        i rarely tell people to search, but they should.
                        and what does searching have to do with bringing up old posts?
                          They search... The find a post, maybe quite old, because they searched, they reply to it because they found a post that deals with what they are talking about and they don't want to get yelled at for making a new thread?
                          1997 Cayenne Red Metallic Camaro<br />3.8 V6 M5<br />SLP Cold Air Intake<br />Ceramic Coated Pacesetter Headers <br />Flowmaster American Thunder Catback<br />Full 3.42 & Disc Break Rear End Swap
                            Originally posted by Distephano:
                            </font><blockquote>quote:</font><hr />Originally posted by Ian:
                            </font>[/QUOTE]for real the search and find old post, bring it back from the dead then get flamed for that, so what the hell are they supposed to do
                            www.turbov6camaro.com
                            1997 3800 Series II Camaro
