Where exactly is it, and is this something I can do in my apartment parking lot? I did my PCV valve with no problem, but I can't spill a ton of coolant in my complex. THANKS!
Changing my T-stat today!! Questions please.
Go to Install Universityfor instructions. Click on Install Documents. Scroll down the page and find 160 thermo replacement. The instrustions and pictures are for a LS1, but the V6 is all but identical.
[ March 27, 2003: Message edited by: Red2K1 ]</p>2001 Camaro M5 Coupe(1 of 2,737), no options, Whisper Lid, K&N Air Filter, Free Ram Air, MAFS Screen removed, SLP Manual Fan Switch, 160 thermo, DEE\'s T/B Spacer, EGR Block-off plate, IAT resistor, CAI to EGR air feed, B&M Ripper Shifter, SLP Replacement Grill, T/A Exhaust, SLP five spoke take-off wheels, BMR strut-tower brace, BMR Tunnel Brace, BMR 32/21 front & rear sway bars with poly, BMR Poly/Combo Rear Control Arms, Clear front & rear corners, HPP3 modified 87 Octane program.<p><a href=\"http://www.cardomain.com/id/red2k1\" target=\"_blank\">http://www.cardomain.com/id/red2k1</a>
If I'm not mistaken the V6 is quite a bit different than the LS1 on not only location, but also replacement of the thermostat. Go to this boards tech section nd there should be an install guide by Cardinal for this...It was perfect, and I changed mine the first time in under 5 minutes start to finish.<a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">www.fullthrottlev6.com</a> THE SOURCE!
